Overclocking questions
Id_Login
Ok I,ve got
AMD 3500+ CPU 2210mhz
XFX Geforce 6800 Ultra @ 456mhz, 1.2 ghz
1Gb Corsair 4400C25PT memory
MSI K8N Neo Platinum 2 Board
I would like help with some settings.
So far I've clocked my cpu to 2605 mhz using these settings.
Memory timing 2T
cas latency 2.5
ras to cas 3
min ras active time 8
row precharge time 3
max memory clock auto.
HTT x4
Cpu ratio x11
fsb 237
agp 66
CPU vid 1.55v
cpu voltage over vid 5%
Memory voltage 2.85v
agp voltage 1.65v
Can anyone give me advice on what effect these setting will have eg. dropping htt to 4 does this effect bandwith. Would it be better to drop the ratio and what effect would increasing the agp frequency have.
drop the htt even further to 3 allowing you to up the fsb even further ow and it has no effect on bandwith afaik .uping the agp freguency would cause an unstable rig hence to crap mobo`s not having an agp/pci lock
set agp to 67 which will lock the pci/agp bus. you can drop Cpu Ratio to 10x and see how far you can push the HTT (FSB). AT 237 having HTT at 4x is fine.
