Overclocking Problems
mVp24
Well, everyone with there new flashy Core 2 Duo ownage has got me sad. I started to explore OC'ing after a while to finally have a little power in my ole system.
So these are the settings that I've tried so far.
FSB: 930 -CPU: 1.3875V
Ram Speed: 666 mhz - 2.0V
Bios Temp: 31C
Problem: Freeze in POST
FSB: 925 -1.3875V
RSpeed: 666-2.0V
Bios Temp: 31C
Problem: Freeze while booting
WOrking setting:
FSB: 920-1.3875V
Ram: 666 mhz- 2.00V
Bios: 31C
Idle in Windows: 26C
Super PI 1 M: 38 Seconds
(3.45GHZ in Windows)
Multiplier is 15.
System Temps: 39C
GFX Temp: 31C
Temps taken in Nvmonitor (besides bios)
Any advice? System specs in profile. Please help me! Thanks guys!
Wow can't get any looser than that... Ok, hrmmm.
Try running your ram @ a 1:1 divider, try upping your vcore a bit, and try your vdimm at 2.2v. Also, make sure you give mad voltage to your northbridge, P4's NB needs to get some die-hard volts, but once you do that you can really unlock the potential of a P4 :) Right now sounds like ur RAM could seriously be holding you back if those are the stock timings.
U mean 1.4v? yeah, ur definately save there. And 2.2 is perfectly safe for your RAM as well. P4 / PD, all the same really :p hehe
And if you don't have control over the NB voltage then u could be up crap creek w/o a paddle.
Damn I just found that this current OC isn't PI 32M stable. I think i fell into the creek :[
I feel that if it is stable with what you reguarly do like game and such then its stable in my books.
