wrenaudrey
Member
i7 4770k
Sabertooth Z87
8GB Dominator 1866
EVGA GTX 780
Samsung 830 128GB
Cooling
EK Supremacy CPU Block
XSPC Titan Block
Alphacool D5
XSPC D5 Top
Phobya Balancer 150
Alphacool UT(stands for 60mm thick for those who doesnt know) 360 and 240
5x SP120 all in a PULL config
Windows 7 Ultimate 64bit SP1
I've had my system(full system with watercoolong) for couple of weeks now and the temps are not too bad.
Now i want to try overclocking it. At the moment everything is on AUTO, the only setting ive changed is to set the XMP profile for my memory.
Before i want to overclock, i want a couple of questions answering.
So i've watched TTL's overclocking guide on 1155 and he said there to establish the most base(lowest) vcore. I've been trying to do this with failure atm and have been running to some weird OS issues, i say issues because i've never encountered this before.
So the question is, DOES THIS NORMALLY HAPPEN?
I dial in a vcore eg. 0.950, press F10(save & exit). Then it POST's, tries to BOOT, get to the Window animation thing, completes it then stays there for a bit then BAMM! It restarts, gets to the same point BUT this time it boots into Windows Repair or Startup Repair or whatever its called.
Obviously i repair it, then after that it restarts but happens again.
This kept happening until i changed the BIOS into default settings, so pressuming its the vcore. Does this really happen if you fail undervolt pr is it just me?
Also as i said i needed to reset to default BIOS settings, sometimes i get into the BIOS but then if i dont move fast enough, it freezes :S
Is this normal too or just me?
I want to establish my base vcore because if i dont see a big diff when ive OC'd ill come back to this base vcore and run stock frequency.
So if you guys could help me with this problem first before helping me further with pushing my 4770k
Thanks
Sabertooth Z87
8GB Dominator 1866
EVGA GTX 780
Samsung 830 128GB
Cooling
XSPC Titan Block
Alphacool D5
XSPC D5 Top
Phobya Balancer 150
Thanks
