Jeez, you keep starting threads...
What are you using to measure temperatures?
use asus probe and corsair temp!
trying to get my posts up,,, want to learn more about pcs and what i am running
You might not want to get an 8350 just yet. Sadly I don't think your motherboard would be up for it. You could get a 6300 instead if you want a nice, cheap upgrade from your CPU. ^_^o right thanks but do you think i could get any more out of this cpu and i know its a bad cpu cant wait to get the 8350.... thanks by the way
Technically only you can tell us whats in your CPU - someone explain the silicone lottery to him for me please!
Basically, Santa Claus and his team of elves work very hard to make the CPU's but they always end up slacking off... Thats why some CPU's are good overclockers and others are bad. As long as they perform at the advertised level, they are shipped to you.
This explaination is as close to an answer as anything.
Will just put in a good work for the FX6300, mine OCs all the way to 4.6 with only a tiny voltage bump (thermally limited by arctic freezer 13)... does great in games, destroying it's price competition, i'3s and the like.
I also do some music production work and I can tell you for productivity the 6 cores are a blessing![]()
thanks think i will save for the 8 core 8350 lol might look at the 9 sometin
but need to look at new motherboards as mine is falling apart
