andrevautour
Damn, that's a shame, hopefully they can figure out what's going on and fix it. In the meantime, I tried using the second XMP profile at 2133, and still it hates Sleep Mode; can anyone link to a beginner guide to overclocking RAM? I want to try downclocking to 1866, but I'll have to do it manually(there are only 2400, 2133, and 1333 available by default in the BIOS) and I've never gone anywhere near RAM OC'ing before.
all the kits ive had run 1866 at the same settings as 2133 and run fine /wake from sleep etc at those settings just try setting where it says dram speed set it to 1866mhz and leave the timing at auto and the voltage will set itself too but you can set it manually if you want and try that it should work fine.
if you're trying to get the tightest possible timings at 1866mhz then i dont know about that but i dont know if timings matter much with ivy bridge ( i dont think they do )
