Hi from a newbie, Ive just overclocked my gtx 260 when i googled the overclock i found that peoples numbers were to say the least confusing so i thought i would ask you guys my stable (60 mins) overclocks are as follows
core/shader/memory
756/ 1584/ 1215
Max temp with stock fan is 78 degrees
My question is:
Are these numbers any good or not, if not what would be considered good or what are your numbers
i have a gaiward gtx 260 gs at stock 625/1348/1100 thats quite an overclock you have i expect im folding on mine 24/7 n temps are 74c so if that is stable with those temps you should get some benching done some good point to be had
