mrDMxtreme
Hey so the watercooling place i will be buying my loop from is get the new xspc kits in next week, (i'm not sure if they are custom by him or if xspc are making them like this) but anyways it will come with the EX series rads and the raystorm block.
My questions are:
1. If i buy pre-mixed coolant like THIS do i need to add ANY thing else to it???
2. since it's a new loop with all new components, do i need to fit everything and then run it with hot water for a while to clean it, and then drain it all and then rinse with distilled water, drain it and then fill it with my colored coolant?? or do i just straight away put the coolant??
3. any tips or tricks you guys have found out when you built your first loop?
Thanks guys you're the best
My questions are:
