skinnyck
Ive still got this problem with bluescreening and iam proper pulling my hair out an i know ive posted this before but i really need some help
ive had this board
Asrock G41M-VS3 R2.0
8gb ddr3 of gskill
gtx 460
An old q6600 but ive had it overclocked to 3ghz over its regular 2.4ghz
an the ram running at 667mhz thats been stable on air for nine months seems to have happened after i flashed my bios but not sure if it is that is the culprit im gunna post my bluescreenviews up
now ive changed out the hard drive an still having BSOD,S on ethier of them re-installed windows two or three times im thinking its some sort of windows driver corruption.
if anyone can take a look ill owe you a beer computer name: NICO-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8588976128 total
VM: 2147352576, free: 1933422592
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 02/09/2013 14:33:26 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090213-22875-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x4ADE7C)
Bugcheck code: 0x124 (0x0, 0xFFFFFA80084E3038, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Mon 02/09/2013 08:26:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090213-20078-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008E65028, 0xB2000040, 0x800)
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
On Sat 31/08/2013 21:21:29 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083113-24546-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008492028, 0xB2000040, 0x800)
On Fri 30/08/2013 15:19:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083013-20937-01.dmp
This was probably caused by the following module: hal.dll (hal+0x1DB07)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800842C028, 0xB2000040, 0x800)
On Fri 30/08/2013 12:54:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083013-22312-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008FD1028, 0xB2000040, 0x800)
On Thu 29/08/2013 18:23:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082913-22390-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008FDA028, 0xB2000040, 0x800)
On Thu 29/08/2013 14:37:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082913-23984-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80079A9028, 0xF2000040, 0x800)
On Fri 23/08/2013 05:50:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082313-17828-01.dmp
This was probably caused by the following module: hal.dll (hal+0x11FFB)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007A97028, 0xB2000040, 0x800)
On Thu 22/08/2013 20:57:16 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082213-25171-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007A86028, 0xB2000040, 0x800)
On Wed 21/08/2013 16:33:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082113-27484-01.dmp
This was probably caused by the following module: tcpip.sys (tcpip+0x5A6C2)
Bugcheck code: 0xD1 (0xFFFFF3000F6BD000, 0x2, 0x1, 0xFFFFF8800165A6C2)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\tcpip.sys
description: TCP/IP Driver
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Tue 20/08/2013 18:39:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082013-20875-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007AA6028, 0xB2000040, 0x800)
On Mon 19/08/2013 06:10:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081913-36093-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800849B028, 0xB2000040, 0x800)
On Sat 17/08/2013 17:53:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081713-40546-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008463028, 0xB2000040, 0x800)
On Sat 17/08/2013 16:44:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081713-37828-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800841A028, 0xF2000040, 0x800)
25 crash dumps have been found and analyzed. Only 15 are included in this report. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
unknown_module_00000000`00002021.sys
unknown_module_00000000`00000002.sys
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
sorry its so long
ive had this board
8gb ddr3 of gskill
gtx 460
Crash Dump Analysis
sorry its so long
