Old AX series pci-e cables on a RM750
frufsa
Does annyone know if its posible to use the old ax series sleeved pci-e cables on a RM750 psu?
Dont need the 24pin or anny of the other cables, just 1 pci-e cable.
If you have a multi-meter then you can check the pin outs on it and make sure they the same, then yes you should be able to, but doing so at own risk
Considering they have completely different OEMs I'm assuming you can't.
Also, Corsair sell braided cable kits for both units, but they are different kits and don't seem to be compatible with each other.
From what I've gotten to know after being in touch with Corsair Support regarding cabels for an HX850i... the answer to your question is a no unfortunately. They aren't compatible, since it's 2 different PSUs (basically what Feronix said above).
