alienware
Banned
Warning. This is some really deep mind bending chit here..
So after doing some reading about OCgenie I decided to have a play. Now in my actual bios the only thing it will let me do is clock my CPU to the max turbo speed of 3.4ghz.
However, after reading a review I saw them mention the fact that you can access your bios completely and fully within Windows using their ClickEFI software.
What happened after is so weird and freaky that I bet no one here can explain it..
So I loaded up ClickEFI and I got this.. I then enabled OCgenie.
OK so as we can see I now have full, unlocked control of my CPU..
So, I upped both the regular multi to 40 and the GT multi to 40.
For a while it looked like my PC had crashed, but after about two minutes I got this.
OK so I rebooted and pressed Delete to access the bios (because these settings I'm seeing in Windows are not there in the actual bios) and I got a message on the screen in yellow saying -
You have enabled OC Genie. Please do not change any settings in the bios.
OK, furry muff. So, in I went for a look.
And to my amazement the CPU had actually overclocked and was showing the full speed in my actual bios
But... When I went into Windows and loaded CPUZ I got.
So come on then, explain that. How can my CPU be overclocked in my actual physical bios yet, when I get to Windows it isn't.
