I was just going to come back here and report my findings as it goes !
Buy the Asus. End of. Gigabyte has 6 phases rofl. 6 phases for a 8 core, they're mental !!
Reasons to buy Asus.
1. Better bios.
2. Better looks (IMO, though is subjective)
3. It's the best at clocking memory (fact)
4. It's level with the Asrock Taichi for overclocking (fact)
5. It has AM3 holes, so if you have a water block you don't have to buy a new block or adapter it will just fit straight on.
6. Best power phases. Has power phases dedicated to the memory, same as the CH5 AM3+
From Gibbo of OCUK yesterday.
We just tested a 1700, it hit 4.0GHz stable in everything, but ONLY in the Crosshair mainboard, the lower-end boards it was hovering around 3.80GHz as the VRM’s were cooking with extra voltage. It however was maxing around 4050MHz, so I’d say 1700 can do 3.9-4.1GHz, of course the 1800X will probably do 4.1-4.3 as no doubt better binned, but if your clocking the motherboard has a big impact on the overclock and so far Asus Crosshair and Asrock Taichi seem the best two.
http://wccftech.com/amd-ryzen-7-1700-overclocked-4ghz/
And I was absolutely right. DO NOT buy the 1700x or 1800x. You are paying a ton load more for 200-300mhz. NOT WORTH IT !
I'd like to agree since I always buy ASUS, but you have to admit, they really do milk us for the money. These days I think their price v performance is way out of whack.
I think you will find that is Intel. Asus are selling a top spec class leading board for AM4 for £250. Compare that to this, for example.
https://www.overclockers.co.uk/asus...cket-2011-ddr4-atx-motherboard-mb-68b-as.html
And bear in mind that the Strix may end up being a lower spec board than the Crosshair...
At the end of the day you get what you pay for. I will always buy Asus motherboards where and when I can because for me they have been the best.
Quick example here. AM3+ Crosshair V FZ. 8+2+2 phases. 8+2 for the CPU, +2 for the ram alone. Has an extra 4 pin connector.
Now I would imagine the CH6 uses the same approach. Mainly because it too has a 4 pin connector. So let's assume that it too is 8+2+2. That would be why it is the only motherboard on sale that can run DDR4 at 3200+ speeds.
So basically yet again Asus have a winner on their hands. Gigabyte are off in god knows land with 6 phases on their highest end boards (yet to be completely proven).
