Odd issues since swapping cards.
paulstung
I swapped my 7850 for a 7950, along with my ram. Since changing cards I have had 2 bsod's, I say the card as I've ran mem test and all as it should be with the ram. The stop code I'm getting is 0x000000F4 i have done a Google search but can't pin the what it is, there are too many ideas to what it could be.
I've been trying to run the 3d guru in OCCT but I keep getting a strange message Crysis 2. exe has stopped working. Also I ran a Heaven benchmark and it just didn't look right. As far as gameplay all is running except for Crysis 3, at first it would crash every time I died, as it would ask you to press f to restart, it would just freeze. I went away had some food, and came back to it now it won't load at all.
I swapped over to my 7850 and occt started but it got to about 16000 errors and just stopped the same as before, just a black screen. I can't try a different pcie slot as with it being on water, the hose won't reach to the next slot down. any ideas guys ?
just as I finish typing, my psu started to make a noise, when I push the top or the corner it stopped. it is fan down.I've just remembered that on the first bsod, I had put a small oc from 800 to 900. Also every now and then when opening a game, a window pops up about the Windows color scheme
