Odd but really effective cooling, and now I'm ready for real O.C'ing
Multibox1
I just purchased a H100 by corsair. I know, it's not what any liquid cooling advocate would ever choose. These closed loop systems are almost always beat out by the manually built ones, but hear me out. I don't use a 'case' per say. I build a stand for my computer that everything just kind of sits on out in the open. It makes manipulating parts, and switching drives (which I do a lot), much easier. Oddly enough, the temperature of the CPU hasn't changed since moving away from cases. I just keep a nice can of air around to blow the dust off, and any other creepies that work their way onto my mobo.
But enough about that, back to my H100. It was installed and mounted into my windowsill, so that it pulls the air from outside (through a series of makeshift screens to avoid contamination, and a windowsill mount that lets me close the window on top of the radiator). It also has a push-pull configuration, and all the fans are always on high. After 30 minutes of idling, it rose no higher than 9C and went no lower than 5C. 5 Hour torture test results ran no higher than 20C.
Can you help me reach stable 3.6Ghz?
(AMD Phenom II x6 1090T)
What motherboard are you using? It is really easy to overclock that chip pretty much no matter what. I got stable 4.0 ghz with auto everything. I just set the multiplier to 20 and base clock at 200. Booted up, 24 hours of Prime95 completely stable.
I can give you more information once I know what motherboard and bios you are using though.
Edit: I also have the 1090T. I should have mentioned that in the original post. Heh.
I'm using an ASUS M4A78T-E. I just ran Prime95 for an additional 5 hours, still no shot over 20C. Just bumping up the Multiplier will give me a stable O.C?
