OC3D Article: How to clone your Notebook / MacBook Hard Disk to an SSD
JN
"Swapping your Hard Disk for an SSD is one thing. But transferring all of your data and OS? Well that's something else. Join us as we walk you through the process step-by-step."
Read More
Nice one there Jimbo.... Very nice write up and not even a single typo that I could see :o..
Tis good to see something a little different in an article on occasion.
*wants an SSD*
SSD I said!!!
Cheers for the feedback guys. Hope it wasn't too dumbed down for the intellectuals that frequent the forum :)
Truth be told it took about 1.5 weeks to put this article together because finding 'free' software that didn't trash my Windows install or completely knacker my Mac was hard to come across lol.
Intellectual? Hmmmm.
Great little article though, its something Ive never done so found it a really good read.
Thanks for the article, it's always nice when people go through death defying procedures to assist others.
Years ago I once trashed a system using Norton Ghost not realising it didn't support SATA. The really stupid thing was a few years later I repeated my mistake. The Norton CD was very quickly destoyed.
Quick Question on this Subject
Hi Jim :)
Thanks for the ace article which is actually very relevant to me as I am going to buy a OCZ Aguility 60gb SSD next week for my system.
Quick question thou can you clone a RAID0 array and then put the image onto an SSD.
Just wondering as I currently have 2 x 36gb Raptor drives in RAID0 and was wondering if I could tranfer this onto the SSD.
Many thanks for any help :)
name='Judderman' said:
Hi Jim :)
Glad to be of some assistance :)
The cloning of a RAID array is definitely possible, but it does depend on what RAID controller you are using (ICH10/Jmicron/Marvell/Adaptec...etc) and whether the software I mentioned supports it.
As your Raptor array is smaller than the SSD you wont need to do any resizing, so the only thing you need to worry about is support for the array in CloneZilla.
I did notice that it supported a LOT of adapters so you might be lucky.
Yeah, ur issues start when u want to clone from a single drive to a raid array, other way around works fine. Generally cos when people install their OS they don't have ACHI enabled, or set to IDE, which means that the OS install inherently doesn't install the controllers drivers. Setting it to atleast ACHI and installing ur OS (setting it to IDE afterwards) is the correct way. But u'll not find a dozen people who do it. I don't myself, but I know the issues it causes when u don't.
Great guide Jim. Just to variate the theme, the Mac OS stuff can be done completely from DiskUtility - this is ofc if u have ur OS cd/dvds. Personally I prefer to make a TimeMachine entry, install the OS fresh, and migrate from the entry.
Yeah funnily enough I Did give DiskUtility a go as you can make images of the drive and then restore them on to another drive. Unfortunately it didnt work from me downsizing from a 300GB to a 120GB. Mebe I missed sommit
2 options I can think of off the top of my head, is that u could have either resized the 300g to 120g, which is a simple grab of the partition outline and move it. Or when doing a backup image, do a file version. Not tried the latter tho.
RAID0 to SSD
Many thanks again Jim :)
The RAID controller is just the onboard RAID controller on the AMD chipset. I only really put the 2 x 36gb raptors in RAID as I wanted to have a play with RAID and the drives were sat on a shelf.
My overall plan is to buy 2 x 60gb OCZ Aguilty and put them in RAID0 for o/s and installed programs, then have 4 x 1.5tb WD Green drives in RAID5 for storage. Problem is I only have the money to buy 1 x SSD drive a month.
Many thanks also to Rastalovich as I didnt know about AHCI, least now I should hopefully be able to transfer everything from RAID0 to single SSD then back to RAID0 on 2 SSD's :)
Happy days :)
Just cloned my 500G WD to Intel 80G SSD using the clone option of Acronis True Image Home 2009. Worked like a charm. 25 minutes to clone 45G of data and then 5 minutes to switch the disks in this Dell E6400. Shorter boot time, about 50% quicker program starts. I'm a happy camper now...
Christer
Yeah I was going to say Acronis is pretty decent for a simple clone operation, plus its free trial for 30 days.
Yup and if you choose Manual Settings it can shrink the partition to fit the new (often) smaller SSD disk. So no changes at all are made to the original disk!
Christer
nice guide, but there's no mention of partition alignment...
does clonezilla keep partition alignment or break it like acronis, ghost, et al. ?
