Hi All,
I have some real problems OCing my rig.
It runs all the 3DMark programs fine, but now it just reboots or fails the bench.
Specs:
Mach 11 GT
Epox 9NDA3+ nForce3
1 x FX55 @ HTT 275 Multi 11 HT Freq x3 vcore 1.7v
Chipset 1.7v
2 x 512 MB Gskill pc4400 slots 3&4 2.5-4-4-8 @ 1T vdimm 2.8v
1 x X800 XT PE CAT 4.12 Fast Write disabled @ Stock
2 x Samsung Spinpoints 160GB using the onboard RAID ( RAID 0)
1 x OCZ Powerstream 520W
It passes OCZ Memtest86 four times error free and prime it is stable.
Could it be that RAID 0 i.e. the onboard cannot handle 275 HTT ?
I checked the AGP/PCI lock was working i.e. 66/33Mhz.
It seems no matter what i do it just crashes in 3DMark, did'nt even bother testing games.
Is it just a crap board and should i get the MSI Neo2 ?
Could it be getings corruption with RAID at those speeds ?
Should i reinstall without a RAID setup and just connect the SATA drives as normal ?
It's just doing my head in at the moment, btw it runs perfect at stock speeds as it should.
Many Thanks,
M8tRiX
Specs:
Mach 11 GT
Epox 9NDA3+ nForce3
Chipset 1.7v
Many Thanks,
M8tRiX
