NZXT Noctis 450 White rad help
umarsbid
Hi well today I was doing research and found NZXT Noctis 450. I want to know what's the best set up for this?
I am new as for buy a Radiator and want Radiator that has protection of over screwing as i am new i don't want to over screw it and break in fins ect.
What do you recommend?
Its not easy to damage a radiator, if you use the supplied screws and some common sense, you will not encounter any issues.
Just grab 2 360 rads, one thick for the front and one thin for the top. Take a look at the Alphacool, XSPC rads etc, they are all pretty good. I personally like Hardwarelabs.
Hi what the best Hardwarelabs nemesis rad to buy for this?
I am confused in which line up to pick up?
Would like help with this.
Just read some reviews and decide which model you like best depending on the fan speeds you want to run, some radiators are best with high speed fans and some are best with low speed. Low is usually the way to go for silent cooling.
Hi are smaller raiders good for gpu cooling as I did see
DarkSide - Triple LP360 Extra Slim Radiator
Dimensions: 396 x 121 x 27.5mm (L x W x H)
I was going to have one loop with gpu and cpu.
