NZXT brings PC lighting to the next level with HUE+ RGB Kits
WYP
News Guru
Have a look at NZXT's HUE+ LED kits, with 8 colour options and a tonne of customizability.
Read more on NZXT's HUE+ RGB LED Kit.
This is really awesome! Hope it's going to be more available in my country than the Corsair option (which has one domestically located retailer). This would really put the spark in the theme of my next build :D
This is pretty cool. Depending on the cost I think it will be popular. Only downside I can so to it is the controller's size as you mentioned WYP. In a M-ATX case for example you would have trouble trying to find a spot for it. I think if they included a 5.25" bay adapter for the controller it would be a good fit for it. Actually make use of them instead of something like a bay res.
I stick my ... was going to say junk but I know what that means in the US.... umm peripherals in my 5.25 bay. Things like Firewire (I know right I should just cut it off) or Xbox 360 wireless dongle. No adaptors so to speak. Just some double sided tape or if it's large enough just tuck it in. :eek:
This looks like it will mount pretty much anywhere. Might look at one of these and a Grid+ to get all my fans under control and some lighting. I have an older case and motherboard so fan control is half manual and half set in bios (no fan curves allowed)
