Nvidia's RTX 5090 will reportedly feature dual-slot cooling solution
So basically it is a 5080 that will be sold as a 5090 then.
Well... this coincides with the other rumour that a 5080 will release before the 5090 for once.
With all these leaks floating around, im guessing the 5090Ti will return.
To quote rick and morty...
5090 is just a 5080 with extra steps
That was how they used to do it yes. So for example..
970 and 980. Show offs all buy the 980. Drop the 980Ti a short while later for another sale.
1070 and 1080. Show offs etc etc.
So it sounds like they are back to that malarkey. Probably because AMD have said they are not going to compete.
