NVidia Surround Question
just leave it like it is its normal that widows gives you 2 dif screen sizes because you have a 24 inc and a 19 inc
+ they are more then likly running different resolutions
here is mine
this is how i set it up true windows
i got 32 inch as main screen and a 17 inch sub screen 4 off work
dont mind the mess this was when i set it up furst
i play games on the the big screen wile watching movie on smal screen ore brousing oc3d formum xD
now if you wont both screens ore 3 screens to work to gether perfect i woud sugest going 4 2*ore 3* same size
ore els you will always have 1 screen taler then the other and have a wierd vision + it will b easeyer to get the correct resolution
i hope this helps
