JezEngland
I'm a little troubled at the 570 vs 480 results. I read the 570 GF110 is like a GF100 with GF106 together. Most 480's are deerer to the 570 today though SCAN has the cheapest on pre-order at £208 for a 480.
480 has some better than 570 scores on the link provided
Maby a GF100 using 512 Cores will top alot of benchmarks today and would it have over 1.5GB memory? The 580 GF110 is smooth and faster round CRYSIS benchmark.
Link: http://www.guru3d.com/article/geforce-gtx-570-review/16
480 has more memory than 570. Metro 2033 at max settings + NVIDIA Control Pannel 3D setting on 2 way SLI 480 nearly uses 1.5GB on each card with 1920x1080p and with proper excellent playable settings, lower settings is usualy under 1GB each
NVIDIA should have put a vapour cooler on the 480.
Reasons I've seen for 480 not using the whole chip 512 cores is manufacturing problems, though no confirmation. Do you know?
Here's the stats: http://www.guru3d.com/article/geforce-gtx-570-review/2
On Crysis benchmark the 580 uses more electricity than the 480
GPU thermal threshold GTX480/470: 105 degrees C vs GTX570/580: 97 degrees C
A forum user wrote in my other thread that probably Nvidia used money made from the 400's to fix the issues and release the 500's. I think Nvidia didn't make a massive profit with the 480's, 470's as initial benchmarks, reviews didn't favour the heat and noise. They sold alot of 460's
I've OC'd the 480's 160mhz at 80% fan speed at with safe temps leaving room for more OC'ing and higher temps
And I've been troubled about the NVIDIA fan settings I've fixed in the Graphics Card Forum: http://forum.overclock3d.net/index....-cooler/page__pid__396640__st__40#entry396640
Is there software to take voltage higher than Afterburner or BIOS lets it be. How do the professional LN2 overclockers get like 1100mhz core clock because it needs more voltage i think
marketing steers alot of manufacturers and I think they've got too much money and should sort us with generouse hardware
First reviews gave 480 a bad look and it's the first Fermi chip with first Fermi drivers, stuff didn't run properly and with new drivers it's alot better. I'm chuff'd with my 480's
580 is great in benchmarks though benchmarkers like overclocking and a thermal limit of 97 degrees C is a lower limit than the 470/480. Liquid Nitrogen time, i dunno
What do you think?
Edit: I've re-done the links they work now
Thanks
