Dawelio
Active member
A gap between the 1080 and 1080Ti.... but what would you call it? Ti is already taken, GTS1080 maybe. :lol:
1080FTG = 1080 Filling The Gap :lol:
That's called an OC 1070.
Vega56 OC seems to be doing fine up against 1070 OC.
Even more so since people have started flashing their BIOS to 64 clockspeeds.
And her that changes nothing. People are still going to buy the 1070. Lower power consumption. Lower heat. "Nvidia". Basically sums it up.
The only way that will change is if AMD produce cheap great GPUs like they did with Ryzen. When the prices are the same, or close, why on earth would you buy from what to you is an unknown company?
The only way to win is to set off people's tight alarms and make the deal so good that they will switch. That is what has happened with Ryzen.
They had that with Polaris. People were getting right behind them and cheering on the pics and posters they were making. Polaris was awesome (note was). Small, cheap to make, high yields, every one can afford a decent GPU for the first time in years = land grab. Then they go in the complete opposite direction with Vega. That is what I just don't understand. AMD were back to doing what they are good at and they seemed to let it go to their head.
Vega die with GDDR and we would have seriously been onto something.
From what we've been told, though, Vega without HBM2 would not have been possible. They were stuck with HBM whether they wanted to use it or not.
Then I don't understand why they are boasting of a mobile APU with Vega. Which will use DDR4 I would imagine.
I'm no expert on GPU design but alarm bells are ringing, Willy*. Also see**
*that is a line from Lock, Stock, Two Smoking Barrels. Willy is the guy's name, I am not calling you a phallus
** Unless of course they are lying and it's not really Vega in the APU but rebranded Polaris.
People with Freesync are not going to buy the 1070.
Vega is a feat of engineering. It really is. Fury was too. The only issue is unless you can get it loaded up and doing what it should it is crap, slow and inefficient.
Vega should be incredible. Instead it isn't. Mostly because it has too much of what we don't need right now, and not enough of what we do.
If I could never buy another GPU again and had a choice I would pick Vega for sure. It will shine... One day.
I have freesync and I bought a 1080.
I also know others who have done the same. A lot of people are using Nvidia/Freesync setups because it's actually becoming harder to find 'gaming' monitors that are affordable without Freesync, and since AMD cards are struggling to compete in the high-end right now, a lot of people are using Nvidia 1070s, 980Tis, 1080s, and even 1060s.
How have you found it coming from an RX 480?
Ships tomorrow.
I don't notice the difference with freesync on/off. So honestly it's just crap like Gsync imo. All marketing. I'm just stuck with it because I can't find anything else that's 144hz without one or the other. And I'm not counting the Korean stuff. I won't risk it.
Honestly I would just like to sell my monitor and get a 21:9 IPS lovely display. 100hz even would be fine. 144hz is not a big difference.
No it really isn't.
Just because you can't see the difference doesn't mean others can't.
You won't. Show me the difference between 144hz with and without freesync/Gsync.
Well I physically can't as I'm on another continent so that's a bit of a stupid thing to ask for ^_^
You can't see the difference, That's fine, But stop trying to lay down the law like it's fact, I can see the difference between Freesync/G-Sync on/off and so to can many others.
I can't ride a fully manual dirt bike so no one can !!!!!!!!!!!!
I can't pilot a Boeing AH-64 Apache Attack Helicopter so no one can and because I say so !!!!!
