Well IMO that is AMD own damn fault then they just keep shooting themselves in the foot, It's just like AMD has just given up then.
No wonder why Nvidia has the market share they do then.
AMD are not shooting themselves anywhere, they just need to take back a huge % of the market to gain investors. The more % you cover the more money you get.
The RX 480 may not be exciting to many, but it will give AMD a leg up in the market. Their aim right now is a land grab. They will do it with the RX 480 and they will then do the CPU market with Zen.
They don't need to be in the driver seat right now.
Dom - I know you're not taking the pee. Over the past few years I have known a guy who lives out in Taiwan and works for one of the biggest PC part manufacturers known right now. Obs not going to go into detail but whenever he reports something he's usually right.
It's not rocket science. Why would Nvidia want to sell you for example a 1080ti with a larger die (up to twice the size of the one you're using now on your 1080) for not a lot more cash? why not wait patiently until you crack all of your enthusiasts into buying a 1080, then when you are absolutely sure you've milked the tits off of this small die then move onto the bigger ones?
Cards like the 1080 are bread and butter. They're cheap to make, success rates go up because you are raising the odds of success and you can get plenty out of a wafer. The larger the die becomes the more prone you are to hitting an imperfect part of the surface for example and the more prone you will be to failure.
The bigger the die the higher the chances of failure. Also less cores per wafer = much higher costs.
Right now the 1080 core is a real sod. Yields are low because of the clock speeds Nvidia want it to run at, hence hardly any stock whatsoever from AIBs. Just the odd few cards here and there. That's because Nvidia are putting themselves and their FE cards first.
Look how long the 1080 has been out for now and still stock is dripping through like nothing. By now with the 980 pretty much every after market card was announced, made and available for sale.
If I am right about the 1060 (vaporware, months before you can actually get them in any half decent volume) then maybe you'll grow to trust my info a bit more
But yeah, this guy is hardly ever wrong and literally visits the factories where GPUs are made as part of his job. So he's rarely wrong, and when he guesses it's a seriously educated one
BTW. Here is some more food for thought.
Before a AIB are allowed to make their own cards they need to sign an agreement to say that they will buy X amount of 1080 FE as part of the deal.
Don't forget things like that. The same goes for AMD. Before AIB could even make their own cards they had to accept a deal on AMD's cards.
