I reckon it's just the bit of silver trim that's missing. That way the fan on the top and bottom of the card look identical
OK, this next part is pure 100% speculation, but could this cooler design be made so that the card literally blows through each other? are Nvidia going to try and make a multi GPU comeback with DX12 Ultimate?
What's triggering me is the fact the image has been flipped lol.
The images have not been flipped, the card has.
You can not flip a 2D image without turning it into a mirror image which would make no sense.
Take another look, the way the PCIE slot and bracket are orientated mean it wouldn't fit in a case.
If you flip the image (the second one) vertically it then is orientated the correct way. Literally just checked using paint lol.
I hope that's not glossy black plastic I see...
I guess, just seems like an even weirder choice, in terms of trying to vent the hot exhaust air. Either way it's clear both the fans are operating in the same direction with each other, as the fan is flipped on the flip side of the card.Its the opposite in my opinion. Looking at the visible fan design we can only assume it turns clockwise so it acts as intake, other wise the fans would need to be flipped if the rotation was the other way. Also the orientation of the PCI slot means this fan is face up. It has to intake the cool air blowing in from the front, and exhaust it out the bottom.
Nah, SLI has always benefitted from exhausting the air out of the case.
You're not looking at it correctly. Look at the bottom card in the pic again with the 3080 logo.
It is just messing up your perception because it is so alien.
It's literally like that time they opened the arc in Indiana Jones.
I might need new glasses... LOL.
I'm not sold on the look but ultimately if the design improves cooling I'm all for it.
