WYP
News Guru
Nvidia has revealed DLSS 4, and it transforms every aspect of DLSS.
Read more about Nvidia's DLSS 4 technology.
40% Boosted speed? When using frame generation, does that mean improved latency as well? I whish GPU manufacturers had more focus on that, and not just getting more frames. Also, I wish Nvidia would stop locking new gaming related software tech to NG GPUs..With Nvidia’s new DLSS Frame Generation model, they have boosted speed by 40% and reduced VRAM usage by 30%. For Warhammer 40K: Darktide, this results in a 10% boost in framerate and a 400MB reduction in VRAM usage. In other words, DLSS Frame Generation just got better.
That bit when he said the 5070 is as fast as a 4090.
LMFAO.
I turned it off after that.
Who said that? It's not in the article.That bit when he said the 5070 is as fast as a 4090.
LMFAO.
Unfortunately AMD is following in their footsteps, the expansion to FSR4 with improved features, will not apply to all FS3 supported cards (as of now). Although understandable, it's a shame IMO.
Well, the good thing about the 5070 is that you don't have to wait a year or two. With only 12gb of vram it's useless right now.There's always a catch with those to make them useless after a year or two which for over £600 is just a joke
It's not going to be 550.
You'll be looking at 600 minimum so same as last time. And no doubt the same performance uplift as last time too.
FE cards are almost a myth and for 600 you'll get le plastic fantastic from PNY or something.
The most fake thing about Nvidia are their RRPs. Surely you've learned that by now?
