Nvidia 158.24 WHQL and 158.45 beta
youpla
Nvidia released their new vista 32Bits driver 158.24 WHQL certified on June 1st.
Release Highlights:
WHQL Certified driver.
This driver fixes a problem when trying to enable NVIDIA SLI using the international versions of Windows Vista.
Increased performance in 3D applications.
PureVideo™ HD support.
Add support for forcing Vertical Sync in DirectX applications.
Updated NVIDIA Control Panel with improved user interface (Please see the Release Notes for more details).
Numerous game and application compatibility fixes.
This driver supports the following 3D features:
Single GPU support
DirectX 9 support for GeForce 6/7/8 series GPUs
DirectX 10 support for GeForce 8 series GPUs
OpenGL support for GeForce 6/7/8 series GPUs
NVIDIA SLI support
DirectX 9 support for 6/7/8 series GPUs
OpenGL support for 6/7/8 series GPUs
Download here: http://www.nvidia.com/object/winvista_x86_158.24.html
Also available are the 158.45 Beta drivers for Vista 32 Bits and support SLI.
Release Highlights:
Improved performance for DirectX 10 version of Company of Heroes
Improved 3D performance for single GPU and NVIDIA SLI
Single GPU support
DirectX 9 support for GeForce 8 series GPUs
OpenGL support for GeForce 8 series GPUs
NVIDIA SLI support
Download here: http://www.nvidia.com/object/winvista_x86_158.45.html
And I don't know if you have already checked the demo on nzone but I found Adrianne pretty cool, much better to watch than those space troopers shooting at each others in 3Dmarck2006 hehehe :D
Check for Adrianne here: http://www.nzone.com/object/nzone_adrianne_home.html
Amazes me how they add the lines "support for 6/7/..." - these fresh drivers are almost always awful for older cards.
Wonder if there is any worthwhile difference in Vista. If the performance is getting close to XP it might convince me to go back.
I don't personally think the performance is quite there yet..
Give it some more time! ;)
