Not much but it's mine
RWitts
i7 920 @ 4.2 Ghz
Asus Rampage extreme II
6 Gb ballistix tracer ddr3 1600
...Asus GTX680CUII
LG HD/Blue ray dvd
...60gb SSD OCZ Technology Vertex 2 (operating system)
500,320 and 1000 Gb Hdd (storage)
Antec 1200 W Quattro Power Supply
Water loop
Black Ice Stealth GTS 360 Radiator
Swiftech Apogee XT CPU water block
Swiftech MCW-NBMAX North Bridge water block
XSPC Dual 5.25” Reservoir
Swiftech MCP355 pump
3 x 120mm Scythe Gentle Typhoon 1850 RPM fan's
2 x 120mm blue LED illuminated Sharkoon 'golf-ball' fan's
Asus O.C staton for fan control
How do you find the outer screens at that angle? I find that if the angle is too shallow, that the far edge of the screen is a slightly differnt hue, and not as nice to read.
Nice setup.:)
It's not too bad the displays have a wide viewing angle and there not that steep, its probably because i have the bezel's of the outer displays behind the middle screen (look,s like a steeper angle than it is)
Bit of constructive critisism, use less tubing, get some angled adapter fittings, try not to cross tubing, and get some BitFenix extension cables. They really clean up the build.
Edit: Great board by the way, I have two of them myself. One with a modified heatsink, and the other with a Bitspower Black Freezer block.
Thank you
it probably doesn't help that i have used 3/4 inch tube
the only way i can think of tidying it up a bit would be if i got a new rad with fittings on each end so the feed from the pump isn't going across the case and some new fittings.
Saying that i do like the look of solid copper pipes
