PetrolHead247
If you're gonna do an epic watercooling build you gotta WC the GPU's too!
How loud is the 680 At that fan speed?
You still cant here it. unless benching, but it's still not noticable unless you are looking for it.
You're obviously going to hear them... Depends on what you find a disturbing noise level?
But why worry about the fans? You're doing an EPIC build, so WATERCOOL them xD
Yes, too true - it is an EPIC build, so I Should just watercool it
I see what you did there![]()
hahalooks like a good build
Please do keep us updated![]()
Do not Worry, I Will make a build log on here, and the Specialtech Formus
