Not able to tweak BIOS settings anymore..
Efekkt
a couple of days ago, i upgraded my version of xp from home to pro sp3. i also reformatted the thing and updated the bios again because i found that i was no longer able to change the settings of my CPU on my bios (computer won't even POST). i thought it was a bios problem hence the reinstalling, but now i don't know what it is. some help, please?
with everything on auto, just the reference clock at 200, it still won't post. even setting the multiplier at 11.5 (2nd highest, right after that it's 25) and reference clock at 200, the computer still won't boot. :/
well, once i alter the multiplier or reference clock, my computer won't post. i then have to reset the bios in order to get into windows.
i also want to add that i'm on an AM2 4600+ processor.
sure thing,
AMD Athlon X2 4600+
DFI LanParty UT NF590
2GB Crucial Ballistix Tracer
250GB HDD
XFX 8800 GT
560W silverstone strider
overclocking was fine before i reformatted and upgraded windows. could that be the issue?
What's the ceiling for these cpus on air ? Isn't it like 2.6/2.8ghz ?
What ur probably having issues with is the fsb in relation to ram.
Try something like putting everything at stock, drop the ram speed from Auto/200 to perhaps 166, see if it boots, then try increasing the fsb.
Have no experience of this mobo tbh.
Try taking out all the ram except one stick at a time and see if it will post at default speeds with each stick. You might have lost a stick of ram and it can give you some very weird errors and not able to boot at normal speeds and such.
I cooked a stick of Kingston Hyper-x after a bout a year of running my X2 3800+ at 2.6ghz,one day I just couldn't boot the machine normally no matter if I went to default settings or not until I found the bad stick of ram which was just by luck and the first one I took out.
okay, i'll try it out. thanks. :)
i doubt it's RAM problem, but no harm giving it a try, i guess. thanks. :)
