Nooby Word question
Toxcity
Mircosoft word has locked my coursework. I can't save it I can edit it I can't Print it.
Whats the problem and how to fix it? :(
name='MikeEnIke' said:
Can you right click on it without opening it and rename it?
Probably could.. (this is a mates problem)
She said that all the options in word is blanked out in gray and they dont work...
Well the it may be read only, my only guess would be to rename it and then try... before using google at least.
can you right click on the toolbar, tick Forms and see if it is locked / protected?
Nooooo!
I would never! :cool:
Its my friend! Shes gone and buggered up her computer (like everyone without a brain these days)
And im tring to fix it with out touching the PC. :D
SKILL! :worship:
