Hi,
I'm new here as you can probably tell. Please forgive me for starting a new thread on something that has certainly been discussed before.
I'm looking to upgrade my PC for gaming purposes. I like to think I've familiarised myself with the necessary terms and knowledge, but there's no substitute for advice from the experienced
My mainboard is a Dell 0WG864 (according to CPU-Z) with a FSB speed of 533MHz. There is no documentation that I could find for the motherboard and so I'm unsure whether the RAM I'm looking at is compatible with my mainboard. Is there any way to tell? If I get RAM rated at 533MHz, will that work, or are there other things that need to be matched?
This is the RAM I'm currently looking at:
Crucial 2GB (2x1GB) DDR2 PC2-4200C4 Dual Channel Kit (CT2KIT12864AA53E)
(it can be found at www.overclockers.co.uk but the link wouldn't work :S )
Here are some of my mainboard specs that might also come in handy:
Manufacturer: Dell
Model: 0WG864
Chipset: Intel P965/G965 Rev: C2
Southbridge: Intel 82801 HH (ICH8DH)
LPCIO: SMSC
BIOS:
Dell Inc. Version 1.0.2
Date: 08/30/2006
I'd also gratefully accept any advice on common pitfalls when performing this type of upgrade.
Any and all help is greatly appreciated. Thanks!
Manufacturer: Dell
Model: 0WG864
LPCIO: SMSC
BIOS:
Date: 08/30/2006
