Noob Q
satman
I have been into the water seen for the past few years and have decided that it was time to take the plunge into Phase.
I have read all the heated reviews comparing the Vapo's to the prommies.
What some only just touch onto is the noise levels.
My systems are virtually silent running total WC so I am looking to try and keep they system as quiet as possible.
The system I will be using as a base will have the following spec.
Abit IC7-max 3 south bridge water cooled
3.4 Prescott
2x 512mb Corsair twinx-xl 2-2-2-5 at 400mhz
74gb Raptor in an Aqua Computers dual water cooled box
Ati 9800 Pro with Aqua cooling block
Silentmaxx 450 watt water cooled PSU.
Bearing the above in mind it rules out a vapo LS so it would leave me with the choice of a Vapo XEII or a Prommie 2 and possible and a Lian Li case.
Phil
Would you know if there would be a problem in substituting a PC60, PC61 for a PC70, or PC71 apart from the overhang at the back of the case.
Any comments on above through personal experience and preferences would be gratefully appreciated.
