Noctua nh-d14 vs thermalright hr-02
KING_OF_SAND
i can only find a few reviews on the "vs" of these two coolers and most of them say the thermalright cools better. can anyone confirm this? if i do get the thermalright i plan on sticking 2 fans on it in push pull so please remember that if anyone has tested these together. thank you.
have you got some links
EDIT-its cool i got some
it does seem mixed but that could be anything,i only trust this site nowadays anyway,it is still the top cooler IMO
well the other thing is that the thermalright is also a passive cooler. if i were to put 2 120mm in push pull it would blow the noctua out of the water by at least 6 degrees. problem is i cant find a place to buy them lol.
Ive got both, the Noctua easily wins out mate. Even if you did use fans its not as good. Because of the HR02's size it really needs high cfm (noisey) fans to get decent temps and the TY140s they send dont really do that job.
DEFFO better off with the Noctua, stop messing about and just accept its epic.
