Noctua NH-D14 in Lian Li PCX2000FB
lord_jamie
Can anyone advise if the Noctua NH-D14 CPU cooler will fit comfortably in a Lian Li PCX2000FB case? I cannot find the internal dimensions anywhere and this looks like a fairly narrow case 240mm, with the Noctus being 160mm tall.
Looks like it will LINK
+1 for mushkin although with something like corsair dominators you can always remove the top bit of the heat spreader and the cooler should fit no problem
