Noctua NH-C12P
fusion1275
Hi all,
I have a coolermaster cosmos-s case and an asus m2n32-sLi mobo but am having some troubles getting a decent heatsink to fit. I used to have a Thermalright Ultra 120 but has to sell it as it was waaaay to big and couldnt even get my ocz memory modules in.
So was wondering if the above would fit? If anyone has the same situation and what they have found works and what temps they are getting idle and loaded.
Thanks for any help?
Hiya,
Quite surprised that nobody replied to this.
I personally don't know whether it'll fit and I've just searched around for 5 mins but to no avail.
Spose you could always measure the motherboard to see if it'll fit.
SOrry, thought that I at least posted the compatability bit.
Yes it will certainly fir your board. But I am not sure that it will fit your ram
Dont think that they give the heights that you need to tell either.
Give them an email, sure they will reply fialry wuick.
