New Water 810
Bullmecha
My new case with my first venture into watercooling.
First shot is it just sitting there minding it's own business.
Next is an inside view while it is off. Cabling isn't sleeved all the way to ends as it is the TX750 i got when I first built it around 4 years ago.Still don't know why my clear tubing looks green
Shot of the front side after it's fired up.
And a shot of the inside while on.
lol thx
Specs are as follows....
I7-950 (clocked to only about 3.22)
Gigabyte EX58 EXTREME
6GB Patriot Viper EMP
Corsair TX750 Power
Sapphire Radeon HD 4870x2
All cooled by xSPC RASA 360 kit with an added EK block for my GPU, surprised I got a new one this late in the game.
Very nice, just one question, does the coolant colour look like that in person? Looks a bit like urine on here. Sorry to be brutal
Otherwise very nice
Yes, it does look like that in the rig when it isnt on..can't figure out why. Used Distilled water with an additive and a UV dye, forgot the UV lights (DOH). The res looks just fine, maybe its the tubing that came with my kit?
Taken without camera flash sitting on my desk.
And with flash.
Can't tell the discoloration in normal lights with it running.
You would think that the silver bezel on the bay res wouldn't go with the white of the case but I think the silver and white go well together, nice rig.
Very nice, but it's quite a colour mish-mash in there. White case with a silver bay res is ok, but then there's orange, blue, black and that weird green colour as coolant thrown into the case. Looks pretty good when the flash is off in the first pic above as the internals look all blue, but in the second pic the colours clash quite a bit.
Yeah I haven't spent the $$$ on all the color matched cables, just used what I had.
The PSU isn't sleeved to the ends as it came from corsair as it sits.
Motherboard is another slight multi color issue.
And for the green coolant, it is supposed to be clear tubing with just water and a UV dye...no idea why it looks that way in the flashed pic.
Otherwise very nice
lol - I'd have said pond water, but that too :)
It does look really neat and tidy - just the tubing is so off putting :/
