Hi, I'm looking to be moving to water cooling in the next 1 month or 2. I was wondering if you guys could maybe help me out on a few things.
Suggestions on what are the best options to buy.
I am looking for something quiet as I don't do much overclocking so something quiet and decent temps is fine.
I need suggestions on a power supply, an easy setup watercooling kit (as its my first time) but able to cool my CPU and GPU and a case (but only if its needed as I didnt long ago buy a new case.) As I dont know if theres enough space in my system for it to go eg, the radiator, or if the empty pci gap above my graphics card, if the tubes will be able to fit through if i have my radiator on the outside.
As for the power supply I'm looking for one which will be able to run a sli config as I will be going to sli after i get the hang of the water cooling.
My graphics card doesn't have a water block on it as its air cooled atm but I have been looking around on how it works changing it and I feel that I will be able to do it.
If you need any info on my system or just a general question then please ask.
I need all the help I can get.
Thanks
Thanks
