new rig
MrSpoon
i want to build a new gaming rig, i'm thinking to get a z68 chipset...anyone have a suggestion to which i should choose?
budget is around £150 for the mobo.
cheapest you can and get a z77 in a couple of weeks
I just built a Boinc rig using a MSI platinum SLI X58 board, £80 from a certain auction site. I flashed to latest BIOS and stuck an i7 980X which cost me £360, also from an auction site. The MSI board performs well, going into the cell menu for overclocking does seems a bit of a time warp compare to my ASUS X79 rig but overclocking was simple enough. One thing that was annoying was the MSI live update feature refused to work saying I had the latest BIOS version, when clearly, I didn't. I don't know what your budget is but there are plenty of cheap X58 mobo out there if want to really get the most bang for your buck.
If you want to go for Z68 I think you'd be hard pushed not to go for the Gigabyte UD4 as it's only £95 on Aria atm
And yes the Z77 boards will be out v.soon, pretty sure mobo release is 1st week in April and new cpu's at the end of April
