New Prmiochill Coolant
Well if the radiator is made of aluminium, well then obviously yes! But for EK's copper/brass radiators should be safe to use
EK has a budget orientated aluminum series too i think. So those are definately out the window on options.
the XE/PS/PE ones are copper. Their A120,A240 and A240G are aluminium rads.
Yeah I'm just not sure which part of "do not use with aluminium parts" people don't understand :)
I would think its an easy mistake to make for first timers. So concerned about not using aluminium water blocks that they forget to check the rad too. After all 99% of rads are sprayed black or white.
I might play with this so long as it checks out. Obviously I will wait a few months to see if any one says it clogged their pump or caused issues or turned poo brown etc.
But yeah does look fun. Would look good in my 08 Area 51 :)
I do love the looks, but I dont trust anything that has so many pigments undisolved in the system. If mayhems advise not to use theirs in the long run, I would think any solution (liquid) used in a loop would go the same way leaving deposits everywhere.
After all, even your basic pastel/coolant deteriorates over time. So with that in mind, what would happen with this one?
