New peltier rig
advancedkill
Hi - I am thinking of setting up a water-cooled peltier rig. I'll cool my gpu with it, which is an ati 9800xt.
The mcw60t vga looks great, and i think that it will fit my 9800xt. I'm willing to buy a case up to the size of a cooler-master cm stacker (I already have 1 and can accommodate almost anything). THe question is, as im new to water-cooling, can the guys at extremeprometeia design a system for me? (im short of time and haven't got a clue on how everything fits together)
What i will need:
1*Swiftech mcw60t gpu peltier
1*triple 120mm radiator (or 2 double 120mm fan radiators)
1*the best pump you guys offer (no consideration for noise) - just the best
1*easily accessible reservior (i understand that i may need to drain the system for various reasons, and that you use the reservior for this)
lots of*1/2" tubing
a load of*barbs - i dont raelly unerstand them, so just tell me what to buy
1*a power supply to power this monster peltier
Thanks!!!!
EDITED BY KENNY: LINK REMOVED, BETTER SAFE THAN SORRY. :)
I'd get two peltiers, a cpu one from coolit which you can get from a well known online retailer, and that peltier for the gpu. Do you need to refill pelltiers?
Mod comment: No competitors please.
For advancedkill: Talk to phil he can put together a kick-ass peltier setup for ya, I reckon :)
name='lamboman' said:
I'd get two peltiers, a cpu one from coolit which you can get from tekheads, and that peltier for the gpu. Do you need to refill pelltiers?
Err... A peltier is an electrical device...its a heatpump, doesnt need refilled, no. My worry is that if you dont REALLY know what you`re doing with pelts, you probably shouldnt be messing with them. Please try it all out on something unimportant first, away from your prized rig.
