New Kit
Chris1303
Hey guys, now i've finally almost finished thought i would post some pics of case. Airflow is pretty good which was the main aim.
Any chance of seeing the specs?
Other than that, might i ask (and im not being rude or inconsiderate) why did you buy a NZXT case??? Im assuming that is the Lexa model?
Just everything is, well, plastic. For the price of those there are some damn fine cases about.
Nice setup otherwise
Edit, i see iv asked for the specs but you have it on your sig. ROFL!
No specific reason for buying the NZXT Lexa case really, it's not a bad case. i used to have a TTVA2000LAN thats was alright. I'm not really a fan of the newer cases that all seem to have Mesh Fronts...
Cheers
Looks Really smart man, i like the colours, and case choice is all about personal preference.
If your planning to replace that 7800 you'll probably need a new PSU that looks like a 480w?
Cheers dude,
PSU is on list of things to change but that will probably be dont before the 7800 is dumped. looking at the tagen range but dont know. Keep looking at the Tagen PSU's with connectors but unsure as yet. Any suggestions? (Less cales the better)
