New H100i Questions
Nazyaweh
I just got my H100i and I had a few questions:
I have seen reports of some units leaking and was worried about ruining my system. Has anyone here had problems with one? Is there anything on the H100i I should check or look out for? Do you like the tubes toward the back or the front? Any other info anyone could give me would be helpful.
Put some paper towels around each end of the connecting tubes and test it for for a few hours, If nothing is there then your all good, 9.999999/10 times there will be nothing there at all.
And it doesn't matter which end the tubes go, Front of back, Only matters which way you think it looks good :)
As Dice said, get something just as a caution for a few hours. I believe Corsair are really good with support if something goes wrong too.
I've had my H100i for over 1 year now and never had any problems with it leaking or anything else , works great.
I have the tubes toward the front of my case , I think it looks better that way , but it really doesn't matter.
Go to Corsair's webpage and download the most recent firmware and corsair link software.
