new commando mobo
pants marshall
hi there i dont post much as i dont really do benching much these days.
so i got a commando mobo, have done the v-core mod and the droop as always,
anyway surprised to see that the commando hasnt got a lower divider from the 1:1.
played a little last night after setting it all up and got a 3.9ghz clock with my 2.4 conroe, limited by my ram, otherwise i would of defo got to 4ghz with it:(, but still its better than the 3.5ghz that i could achieve in the P5W DH:D
pikkie linkage
good old thickie said i can nick his ram to try out before i get some better stuff to run myself:D , i'll get to 4gig!!!
i also have another problem with the commando
i lose the IDE for my cd-rom when i choose raid in the bios?????:(
i have changed the rom for a HD and new cable but without results, i think its in the bios somewhere but for the life of me cant find it,silly as i can see it in the bios before choosing to set up the raid???
any help will be gratefully recieved as i need a fresh install.
gary give me ring i will pm phone number see if i can help
there is a bios setting that disables the ide bus its in with the settings for audio and lan
i would also say up the bios to 0902
hello bazx:)
have got the latest bios for the board(0902), which was fun trying to get it on :D
i'll look in the audio lan part of the bios, cheers for the help :)
hi gary just looked it up
go advanced/onboard devices confi
its called jmicron pate controller needs to be enabled
cheers for your help last night bazx:) got my rom to work;)
those ram voltages havent helped, i think its just the ram flaking out on me.
going round thickies later on today to steal his cell shock stuff :D:D:D.
i'll post more soon as.....
a question for Mr.Bazx
have you noticed a difference in overclocking whilst having the divider set to auto with the commando?
it wont clock well at all if i set mine to 1:1 but in auto i've managed to get my ram stable to 430mhz giving me a clock of 3.870mhz, i have the 1501 bios, i was curious to know if maybe there are hidden dividers within the bios.
hi gary mine always picked 2:3 if left in auto
put memset on your computer it will show which divider you are using
ok i have run memset and it shows me on the 1:1, but if i select it in the bios then i cant get anywhere near the clocks i have at the moment.................weird.
you have trfc set tight there gary try these setting @ 2.3v 1:1
nah... 28 shouldnt be too tight should it? Theres a fair few 954 results on XS at 600MHz RAM with 21-28 tRFC.
sure it can be run tighter but for this oc i would work on the sub timings later
just get the oc working
i'am really on the edge of what the ram can do(its rated to do 266mhz) it does not like anymore than 2.0v currently running it @1.9750v
If i use thickbrits ram i can get a clock close to 4.2-4.4ish, with some work possibly 4.5, but not with my ram:(.
i guess i'll have to kind of steal it from him without him noticing:shhh::D
