jamesriley94
Hi,
Been thinking of all my options of what to do with the Specialtech voucher, and decided it's probably best to spend it on what it was meant for - proper watercooling!
I have a CM690 - which only has space in the roof for a slim 240mm in the roof, and I kind of think if I can only fit a slim 240, I may as well just get an H100i...so I'm thinking of a new case too.
I have a non-reference 670, so no waterblocks for that. I know I can fit another 240 in the floor of my case, but I think it'd look stupid without GPU watercooling to have a tube going all the way to the floor.
So...
I'd like a case that can fit a 360mm rad in the roof. It does need to fit a 60mm thick rad as I'll only be cooling the CPU, but if it ends up having space, then I may as well put one there.
Choices atm are:
600T - and mod in a 360mm
CM Stryker - and mod in a 360mm
CM Trooper - and mod in a 360mm
Switch 810
Phantom 630*
Phantom 820*
*Do think these a both pretty overpriced however.
I'm open to any other ideas.
Now onto watercooling -
As I've kind of said, I only need a single 360mm rad, and I'd like to go with a D5 just for future proofing if I get a reference GPU at a later date.
Kits in mind:
http://specialtech.co.uk/spshop/cus...-Cooling-Kit--D5-EX-Series-Kit-pid-15996.html
http://specialtech.co.uk/spshop/cus...-Cooling-Kit--D5-RX-Series-Kit-pid-15994.html
I'd also consider getting parts separately if people think that would be better.
Total budget is a pretty flexible £450 including the voucher - although I'd prefer not to go massively over as I am a student
Specs are:
3770k, P8Z77-v Deluxe, KFA2 670...
Not sure what else is really relevant.
Anyway, Thanks in advance for all the advice and thanks to Tom and OC3D for making this possible with the competition!
So...
Choices atm are:
Switch 810
Phantom 630*
Phantom 820*
Kits in mind:
Specs are:
