New but old :D
piotrekhc
CPU:
q9540/2.66@3.33GHz
Motherboard:
gigabyte p35ds3p
Graphics Card:
evga gtx 260 ssc
Memory:
g.skill pc2-8000(1001MHz)
Cooling:
Thermalright Silver Arrow
Power Supply:
Corsair 650w
Sound Card:
Asus Xonar D2X(RMA atm:/)/Asus DG 5.1
looking good there matey, just invest a bit of cash in some cable ties and spend a bit of time tidying up the cabled
Finally I had some time to spin silverarrow around and sort some cables like they should be,
, back still a bit messy ^.^, one more thing to get is a longer sata cable so I can route it on a back out of the way.
You've done well with what you've got, looks like a bunch of your cables have to be plugged in further towards the middle of the MB than usual so those are always gonna look messy, if you got some matching colored cables though it'd blend in better.
Also might be an idea to fashion some rubber grommets to hide the cables you can see through the cable management holes. Can't think off the top of my head what you could cut to make them without buying the material though.
Ill get some black sata cables, and ill post update
, I have no idea where I can get some grommets, but ill look around.
