Goggle Eye
Where are you located? Asia **Hardware Import Yes
What is your budget? 7,500.00 Plus would like to stay with in this budget. US Dollars Big cost is the DAC and sound system.
Will you need a monitor, keyboard, and/or mouse included in that budget? Monitor, keyboard
Shall you be requiring an OS? No Windows 7 Ultimate 64 Bit
What will you be using this rig for? Flight Simulator X, small amounts of Video Editing, Gaming typical computer use. Apps such as Auto Cad No.
If gaming, what resolution will you be playing at? Currently 1920 x 1080
Will you be overclocking? Yes
Do you need a full build or will you be reusing some old parts? New Build
Computer Case: CaseLabs Magnum 8 Double Wide.
Optic drives None: Clean Build
PSU Corsair 1200w or the Corsair Platinum 1500w? If there is a better PSU please recommend one.
Air Cooled Build: (Will liquid cool in 18 months after we move)
Ambient Temperatures 23c to 26c Humidity avg 48 Percent
Fans: Times Nine to start: Maximum Number of fans to be used 17
120 mm x 25 mm PWM: NF -S12A PWM 900/1200 RPM Maximum
LGA 2011
Asus Rampage 4 Black Edition
CPU I 7 4930K
CPU Heat Sink Nochtua NH-D14
Memory: RipjawsZ F3-17000CL9Q-16GBZH DDR3-2133 *(PC3-1700)
16 GB (4GB x 4) CL9-11-10-28 1.65v 40mm Tall
A third fan to the D-14 improved cooling by 1c can be added
D-14 clearance fan clips may hit the back of the GPU Can Heat shrink if required. **** Note*** will use a reference card in the first PCIe x 16 channel for a little more clearance.
Clock for Clock LGA 1150 is faster do not want to De Lid not weak at heart and will if required. Strongly considering this route for the 5th gen up CPU and DDR-4.
LGA 1150
M/Board: Gigabite GA-Z97X-UD3H-BK
CPU I-7 4790K will D-Lid if required
CPU Heat Sink NH-D15
Memory: GSkill Z RipJaws DDR3 - 2400 (PC3-19200) 16GB (4GB x 4) CL11-11-31 1.65v 40mm Tall
D-15 clearance issues none. The D-15 will out perform the D-14 per reviews?
For Flight Simulator X is CPU bound. Hyper threading Yes SLI no
Primary purpose for this build FSX. Purchasing a new monitor and will purchase some newer Flight Sims. ROF Iron cross current there is some new flight sims.
GPUs EVGA GTX 780 Super Clocked Reference Cards. For Flight Simulator X a TI is not required.
Should purchase 2 GTX 780s for SLI when needed and no SLI for FSX?
SSD Drives Yes x 2 600 GIG each Please recommend a very good SSD they are not all created equal. Looking for top shelf based on quality, Tech Support and Read Write Times.
1 x 2TB SSD for back up.
Old Hard Drives:
4 x W.D. Velocity Raptors 300 Gig and a Black 2T.B. the 2 T.B
Would the Black 2TB Platter drive be better for back up and storage?
Please recommend a fail safe back up storage and software. Want multiple back ups for this computer.
Should a external hard drive be purchased for back up as well?
Monitor. Please my old monitor is a HP2710m. irt needs to be desperately replaced. Have zero knowledge about monitors other than reading on Nvidia web sight about stutters, shake and bake. Something Nvidia just came out with has to do with timing between the GPU and monitors flipping pages I am lost. Watch movies family videos looking for a top shelf monitor.
Planning on getting a DAC pre amp and Amp and 2.1 Speaker system. My concern. will a DAC read all sound files for flight sims, games, movies and home videos? Spend a lot of time listening to music on the computer. Sound quality is a must.
Head Phones:
Sennheizer PC 350
Want to purchase Sennhezer HD 600s
Logitech 5.1 is history.
Think that basically wraps it up and I want to thank you for your recommendations. Hardware listed my preferences please recommend different hardware or any improvements needed.
Have A Great Day
LGA 2011
CPU I 7 4930K
LGA 1150
Old Hard Drives:
Head Phones:
Sennheizer PC 350
Have A Great Day
