New Benchmark
Here is my run. Not bad for a quite high end system huh ?! :lol:
Edit: forgot to scroll down on HWMonitor :cussing:
I actually find this really surprising. I get 5111 on Tiger preset with my system and yours is considerably better than mine and only achieving in the 6000's on Cat.
Consider buying the basic version (it's pretty cheap) and running a tiger preset i'd be intrigued to see what you get
Heh, I actually think that's pretty cool. A little contest to see who can get the largest difference in their scores, overclocked and underclocked :)
Not one for the how low can you go pile but this is the best I've got on Cat settings.
14655 with a GTX 660ti @ 1250MHz. I thought I'd got a screen shot with GPUZ and Precision X open with my settings but I must not have pressed the button so here's my results screen.
I think I might be able to push the GPU a little more too but it was crashing on stock voltage, am I right in thinking if I upped that a little it would be a little more stable?
Just had another go, This thing gets addictive.
ok, this has been the longest oc session i have had in a while, i knocked my 2500k down to 3.3ghz, with the boost turned off. and knocked my sapphire 7870 down to its stock settings, 1050core and 1250mem, this is that result.
then i ran my gpu at the max i could get out of it, 1185mhz and 1360mem.
compared to the results of maxxed out gpu at the above settings, and the cpu clocked at 4.5ghz,
im surprised how little the cpu clock makes to this, i know this is a gpu test, but i would of thought that the cpu oc would of made a much bigger difference, i mean, cmon, a 1.2ghz oc and only a marginal difference!!
i would imagine that with a basic price of $4, waaaaay more people are gonna buy this than other tools, and they will probs make a fair amount of money outa it
I would be more tempted by this program, if there was an alternative to using paypal to upgrade. Since for some reason last year paypal decided to start requesting more and more private information, I am disinclined to lift the 'limitation' that they applied.
