New AMD build (700 pounds)
taz838
Build coming late January-start of February 2012: http://prntscr.com/4f170
Got an old hard drive off my mate which I am so thankful for!
How is it looking guys, this comes to around 850 pounds.
one question: how far can I overclock with this cpu cooler? Will I get around 3.9ghz?
Cheers people, you guys have really helped me out!
dont' forget to buy a decent cooler - the amd stock coolers are not the best
get a noctua-D14 on it
and get some good thermal paste as well
Will do! The little things will be important! Maybe you can help me out here: will a noctua-D14 and a 560ti fit into an Antec 300. Thanks, I take it the build looks alright?
the 560 will but the D14 will not (too tall)
i have a CM scout with a D14 in it - so it does fit in the one you had in the OP's shopping cart
