Need suggestions.
Kyle sherriff
Greatings OC3D!
I'm building a rig around the Intel i7 2600k
My reasoning for using the 2600k is that I make YouTube video's for a living and I need very quick encoding speeds for After effects & Sony vegas.
Here is a list of the parts I'll be using, if anyone has any suggestions on different parts I should use, mainly the Ram, cause' I'm not to sure on the stuff I've picked.
hope you dont mind me using so meany links. =P
Any alterations are apreciated, as the rig has to last me for a while. =P
-CPU Cooler
http://www.scan.co.uk/products/ante...ler-lga775-1155-1156-1366-am2-2plus-am3-3plus
-PSU
http://www.scan.co.uk/products/700w...ff-sli-eps-12v-140mm-fan-blue-led-56a-plus12v
-Ram
http://www.scan.co.uk/products/8gb-(2x4gb)-corsair-ddr3-vengeance-jet-black-pc3-12800-(1600)-non-ecc-cas-9-9-9-24-xmp-150v
-Case
http://www.scan.co.uk/products/bitf...chable-led-usb3-ready-full-tower-case-w-o-psu
-Motherboard
http://www.scan.co.uk/products/gigabyte-ga-p67a-ud4-b3-intel-p67-express-s-1155-pci-e-20-(x16)-ddr3-2133-sata-6gb-s
-HDD
http://www.scan.co.uk/products/1tb-...720012-sata-6gb-s-7200rpm-32mb-cache-85ms-ncq
-Processcor
http://www.scan.co.uk/products/inte...ad-core-34ghz-gpu-850mhz-8mb-cache-95w-retail
Im confused where is your gpu? and why not use the D14 If you use the D14 you cant get that memory and the 800W of that psu is only £8 more3
would help if we knew the budget you know
ah forgot to mention, I have a GTX 560 TI Already as a birthday prezzie from the misses. =P
Sorry guys forgot to add that one.
Budget is around 800 pounds.
Well tbh if i was you it would go like this:
I7 2600K £240
MSI-P67A-GD55 £115
Noctua NH-D14 £70
8GB Mushkin Ridgeback £90
F3 1TB HDD £40
800w Corsair GameStream £80
Total = £648 (from aria) i think thats everything, i couldnt find the case on aria but it only cost £100 or so, so you have £50 left over for what ever else you might need
