Ghost-Script
I am planing on making a custom Water Cooling Setup, but it is my first time, so i need a littel help.
My System is a follow
Motherboard: MSi Z77A-GD65
CPU: 3570K
Cooling: Corsair H100i
GPU: 2 X HIS Radeon HD 7870 2GB GDDR5
PSU: Corsair AX1200
RAM: Corsair Vengeance - 4x4GB DDR3 1600MHz PC3-12800 CL9
Case: Corsair Obsidian 800D
Sound: Sound Blaster Recon3D Fatal1ty
( MOD Blue Led, instead of Red )
Fancontroller: Corsair Link Commander
And I look on the net and found that I like EK, and I want to have same manufacturer, for the look.
I found this, do I need more or is this okay
CPU:
EK-Supremacy - Nickel
GPU:
2 X EK-FC7870 - Nickel
1 X EK-FC7870 Backplate – Black ( Have one already )
EK-FC Terminal DUAL Parallel 3-Slot
Rad:
EK - CoolStream RAD XT (360)
6 X BitFenix Spectre PWM 120mm Blue LED Fan - Black
Pump:
Swiftech MCP655
EK - D5 X-TOP CSQ – Acetal
Reservoir:
EK - RES X3 250
Fittings:
10 Monsoon 13/10mm(ID 3/8 "OD 1/2")Compression fitting straight - blue
6 X Monsoon 13/10mm (OD 1/2) Rotary 45° - Blue
6 X Monsoon 13/10mm (OD 1/2) Rotary 90° - Blue
Hose: 6 Meters PrimoChill PrimoFlex Advanced LRT - 13/10mm - Crystal Clear
2 X Mayhems X1, Clear - 1000ml.
1 X Mayhems Dye, Blue 15ml.
Thermal Compound: Gelid GC-Extreme
Setup
Is this the best way.
All help welcome
CPU: 3570K
PSU: Corsair AX1200
CPU:
GPU:
Rad:
Pump:
Swiftech MCP655
Reservoir:
EK - RES X3 250
Fittings:
Setup
All help welcome
