Hey guys,
Just finished putting my pc together but all it does when I push the power button on both the case and mobo is turn on and then like half a second later it turns itself off. It then repeats the process by itself until I turn off the PSU.
System specs:
Corsair 850W
Intel 2600K
Noctua NH-D14
2x Zotac amp 580GTX (they should both run with the 850Watts, someone has the same system as I do and theirs runs fine.)
2x 1tb sata 6gb
Gigabyte UD5
I read somewhere that it could be related to the cpu fan control sensor. I had the noctua connected to the CPU_FAN on the mobo but that has 4 pins and the noctua cable only has 3. Could that be the issue?
PS: The mobo light comes on and when I push power, the PSU turns green and all of the fans start. It just turns itself off after half a second.
System specs:
Corsair 850W
Intel 2600K
Noctua NH-D14
2x 1tb sata 6gb
Gigabyte UD5
